The battle against the dreaded P0300
f3ared
Melbourne, Australia
Long time lurker, first time poster.
I bought a 3.6 JKU from the auction yards in Australia a few months ago and have pretty much torn my hair out battling consistent P0300 issues. Its left myself, a mechanic friend [very experienced race engine builder], two other mechanics [40yrs+ experience and run their own machine shop] and a renown diagnostic tester absolutely stumped. Im at the point where i need a new perspective or a new set of eyes over it because everything weve tried so far has resulted in the issue coming back with a vengeance - the longest ive gotten out of it without it throwing the dreaded code and misfiring was 5 days recently. I have pretty much trawled the depths of google looking for answers and am still none the wiser as to what is causing this.
Symptoms; pronounced misfire and driveability issues up to 3000rpm, has no issue revving to redline in gear. Extended idling or cruise amplifies and makes the misfire worse. Have confirmed via JScan, the diagnostic tester and the condition of the spark plugs it is definitely running richer on Bank 2. For some reason, the fuel trims are showing +30% on bank two - we just dont know why.
So far I have done the following in the hunt to remove the ghost from the machine:
-Repaired wiring to Bank 2 Sensor 1 Oxygen sensor
-Replaced PCV Valve on rocker cover [genuine MOPAR] and cleaned inline PCV Valve
-Replaced 4x o2 Sensors with genuine NTK
-Replaced 6x Injectors with Genuine BOSCH
-Replaced 6x ignition coils with genuine NTK
-Replaced 6x Spark plugs with genuine NGK
-Replaced air temp, coolant temp, and map sensors - Genuine MOPAR
-Replaced upper inlet manifold [genuine MOPAR] and checked lower for cracks and straightness, new gaskets. Complete intake smoke tested
-Replaced 4x VVT Solenoids
-Replaced 2x Cam Syn Sensors
-Replaced throttle body gasket
-Replaced thermostat and housing with genuine MAHLE
-Repaired wiring to Bank 2 Sensor 2 oxygen sensor
-Compression test; all cylinders within 10psi of each other [average 150psi]
-Cat temps have been checked both via JScan and infrared thermometer; within 10deg celcius
The most recent discovery was the insulation was missing from the bank 2 sensor 2 o2 wiring near the connection. This was repaired and the car was flawless for 500km before it returned again. At this point, and on the balance of everything we looked at, we do not believe the issue is mechanical [worn cam, rockers, burnt valve] as the compression tests dont reflect this nor do mechanical problems just disappear. Like i said, when its going, its going fine. The issue is isolated to bank 2 according to the scanner and the condition of the spark plugs on that bank. The question is WHY.
On the balance of everything ive seen so far, I suspect there is an issue with the wiring, most likely in the oxygen sensor circuit based off the condition of what ive found there previous and the persistant overfuelling. Does anyone have a wiring diagram for the o2 sensor circuit and a pin out to PCM/resistance values? The other thought is it may be the bank 2 injector circuit causing the problem. If its not the wiring, its looking likely that its PCM and I dont want to throw money on that until Ive ruled everything else out.
Anything ive missed? Its driving me crazy at the moment and I really need this thing to run. Its currently the rather sour icing on a pretty sh*tty cake [divorce, redundancy and now the Jeep]
Thanks in advance
Nick
Reactions: C Hawk
A crap shoot for you, and Im not even sure the JK is included in this issue. The problems were tracked back to defective pins in multi wire connectors.
Just a thought as I know firsthand how frustrating these issues can be.
Reactions: Duster and pc1p
Hey mate,
It does give an avenue to search, so thanks. I have previously found a video where a JK had a P0300 misfire and it was in the multi-pin connector on the RHS cam cover where the pins pulled out of the connector. I have checked that plug and the connectors are seated, however i didnt check if the female terminals were tight over the male terminal like he did by probing them. Also havent checked the PCM side of the connector either, so its worth a go.
Nick-
This terrifies me....
If it makes you feel any better, this car has had a really hard, neglected life. I went against my rule of buying the best car I can afford, and now im paying for it.
Thanks to Gilaguy23s video I had a bit of a brain wave and tested continuity from the PCM pin for the o2 signal wire, back down to the plug for the o2 and found no continuity. Theres no visible break anywhere but obviously something isnt happy and looking at the state of the loom running along bank two, id say the wiring harness is f cked. Tried to run a bypass wire from PCM plug to o2 and whilst the o2 now reads, im getting circuit low voltage warnings. It either doesnt like the gauge of wire ive used, or i need to cut the old wire out of the circuit completely.
Can anyone point me in the direction of the o2 sensor wiring diagrams? I cant for love nor money seem to find one in my searches, and I dont want to cut the wire out until i know for certain theres nothing else connected to it [there shouldnt be, but you never know...].
Also, does anyone know where I can find the PCM pins for the connector? Will get the car going for now temporarily with the bypass wire but once my mate is back from holidays [handy having a good mate thats an auto elec] I think we will need to completely redo the bank 2 oxygen sensor harness from PCM to plug.
Thank you for your response and also keeping us informed with your progress. Sounds like you're on the right track to a successful repair. Wishing you the best. ✌🏼
Just a bit of an update - still havent fixed this...
Previous post i mentioned the o2 wire didnt have continuity to the PCM plug. I attached a bypass wire and got continuity however the B2S1 oxygen sensor will not read over .2v and the PCM is still reporting Lean running on bank two despite visibly being able to see its dumping fuel on that bank. Interestingly when I cut the old B2S1 signal wire out of the loom, it tripped a throttle body code - wtf? Auto-elec mate is finally back from holiday so itll go to him, just need the correct connector repair kit for it. Anyone know which one it is? I had a look at the mopar site but im not having luck finding the one I need - pretty sure its C1
In all honesty, its most likely a dead PCM thats causing my problem but I want to rule the wiring out first because of all the harness issues ive had on that side.
Reactions: Threepointsix
Reactions: pc1p and BLACKJKU
