I IronHelmet New Member Joined Feb 19, 2022 Messages 3 Location Boston Feb 20, 2022 #1 So installing this set up and it calls to “push” bolts through the plate the tire will sit on. How are folks withouta press doing this??
BLACKJKU Moderator Staff Member Lifetime Supporting Member Joined Feb 22, 2020 Messages 4,872 Location Huntington In Feb 20, 2022 #2 When you put the nuts on and tighten them they will pull through and tighten.
V Vman JK Enthusiast Joined Aug 23, 2021 Messages 399 Location Pacific NW Feb 21, 2022 #3 IronHelmet said: So installing this set up and it calls to “push” bolts through the plate the tire will sit on. How are folks withouta press doing this?? Click to expand... You can use a cheap ball joint press if it's too hard to just tighten them on with the nut. Reactions: 72c10
