Tera Flex Alpine Long Arm kit
sgremillion
Louisiana
I recently put a Tera Flex Alpine Long Arm kit on my Jeep and now the rock rails don't fit. What rock rails are compatible with the kit?
A bit more info if you please.
What year and trim level is the jeep and how extensively is it modded? My guess would be that the ones that don't fit are factory rails?
In doing a brief search, it looks like you had to do a bit of welding for that kit. What are the reasons it is not fitting? It seems a bit odd that a kit like that would be engineered like that given the reasons for spending that kinda coin on it.
You should call Teraflex and ask them about it. They're super nice and very helpful. I called them last week with a question about installing a set of Teraflex ball joints.
In case anyone is curious, I was wondering if I needed to grease both of the zerks on the lower joint since the lower joint has two fittings. The tech told me that I only need to grease through one of the zerks. There's one on either side for convenience.
