Temperature gauge doing funny stuff
Doggy-DQ
Walnut Creek CA
I have a 2015 Jeep JK unlimited. I was worried, so I just had a radiator flush performed at the shop and I'm still experiencing the same issue. Under normal load/freeway driving, the temp gauge is rock steady at center. As I climb a grade on the freeway and it downshifts to higher RPM's, the temp goes up to 3/4 hot super quick. As soon as I plateau, drive flat, go downhill within seconds it drops back down to rock steady center. I know the temperature swings in the coolant isn't that quick so I'm just puzzled as to why this happens. Should I even be worried since it always practically immediately drops back to rock steady center? Thanks so much!
I would make sure your electric fan is going to high speed. Also did you change tire size? Before I re-geared my axles my JKU did the exact same thing. I also removed a couple LED lights that were mounted on the bumper when I bought the jeep. I feel like too much stuff up front disrupts the airflow into the radiator.
  • Love
Reactions: TROY66/68
Nice ride! I did a bunch of troubleshooting. I never did get a code reported on the OBDII port. First, I replaced the engine coolant sensor. That didn't have any impact on the gauge reading high temps when downshifting up a hill. So then, I just straight up replaced the thermostat. Cost me $20 for it, and took relatively little effort. I bled the line of air, and took it for a test drive.
Result - rock solid middle of the gauge reading, regardless of RPM's. It would appear the thermostat was the root cause, as it simply wasn't opening up and operating as it should.
OK, been a few days since I've replaced the thermostat. Wanted to let everyone know that my fuel mileage just increased by about 20% improvement! Holy crap, I wish I would've done this sooner. I had resigned myself to poor gas mileage.
Reactions: Rich1961
