Sway bar disconnect recommendations?
Paul K
Farmington, NM
Anyone have some swaybar disconnect recommendations?
It was 10+ years ago, but I had JKS disconnects on my Grand Cherokee. They worked great, once I figured out to use lock-tight or self locking nuts on the studs. I lost one going down the highway at 70 mph because of it.
Actually, the best way to run isn't disconnected at all, it's using a torsion bar such as the Currie Antirock (which is what I would suggest).
They are pricey, but there's a reason all the KOH and professional rigs use a torsion bar and don't actually disconnect the sway bar entirely. This is a much more controllable way to wheel that gives you all the benefits of disconnecting, without the disadvantages.
Reactions: blank
Thank you!
Reactions: Chris
