Novak Conversions Jeep Wrangler YJ engine mounts
Steering issues
Silverbullet11
Indiana
I have 2011 Jeep Wrangler unlimited sport
3.5” lift 35” tires new HD trac bar and steering stabilizers. When driving my Jeep i get this pretty intense shake/wobble from 35 to 40mph. It has snowed here and when driving down the road if I am on snowy pavement as soon as I hit dry payment the Jeep shoots one way or the other. I’ve tried a few things but am running out of ideas.
Lots of potential problems here. What tire pressure are you running? Have you checked the ball joints, tie rod, drag link? Is there play in the steering wheel?
Tire pressure is around 30 32psi I can move my tie rod bar up and down. No play at all in steering wheel.
Have you tried rotating the tires from front to rear? Is the HD track bar a adjustable one so the axle is centered? How about the rear adjustable track bar there also and axle centered?
Tie rod will rotate but should not go up and down. Can you torque it down?
