Squeal from front of 3.6L
tJKrider
SE Michigan
Some background... I was getting some high pitched "squeals/chirps" from the front of the engine after driving for awhile. Nothing at cold start and only would hear it if I was stopped at idle. It may be happening when driving but I can't hear it if it is.
I sprayed a little water, noise went away, so I thought it was the belt. Replaced the belt and was good, but then it came back.
Replaced the two idlers and tensioner assembly and was good, but then came back. One of the idlers had some wobble to it so I thought that was the culprit but, apparently not.
After driving 20min or so I sat in my driveway at idle and cycled the A/C, turned the steering wheel (P/S pump), turned on the heated seats (Alternator), etc to see if I could hear any difference in the noise. No change.
Water pump, perhaps? I may yank the belt and feel the pulley to see if there is any lateral motion detectable. I've also heard of belt alignment issues on these engines. Usually turning on the A/C would detect that, however.
I have a video of the noise but it's too large to load. I'll try to edit it down so I can get it attached...
Uploaded the video to YT:
There are no other indications of anything wrong while driving, although I need to determine if it goes away with other conditions when not moving (higher rpm in park, D but with brakes engaged, etc) .
Let me know if anyone has thoughts!
What brand belt did you use? I try to stick with gates. Did you try the water test again on the new belt? Do you have a mechanics stethoscope? In a pinch, a rolled up piece of paper to the ear may work. Unless you can isolate the noise, it will be hard determine the fix.
Ok, off topic but weird.
@Chris - every see this before?
Yep, Gates belt. I am going to try the water test again and also look at the crank pulley to see if there are any signs of the elastomer shifting. I have read about misalignment issues stemming from this.
Did you ever find the culprit? Having the exact same noise on my 2022 Gladiator Rubicon.
Unfortunately, no. I've been living with it as an annoyance, although fortunately, it's not my primary vehicle.
Outside of this forum I've had others swear they had the same sound and _____ fixed it (choose one):
Belt
Idlers
Tensioner
Alternator
Water Pump
A/C Compressor
Crank Pulley
PCV Valve
I did the first three already, but don't want to keep throwing parts at it. Stethoscope hasn't been helpful in narrowing it down. Interestingly one gent on a FB group had a similar sound (he provided a sound clip) and it occurred in similar operating conditions. He ended up taking his to the dealer and they diagnosed it as the PCV Valve which fixed his problem. Who would've thought? Consistent with this engine, it's not a 5min job to replace the valve so I haven't tried that yet.
We're in the midst of prepping our house for sale so nothing will probably get done for some time. 🤷🏻
Belt
Idlers
Tensioner
Alternator
Water Pump
A/C Compressor
Crank Pulley
PCV Valve
Thanks tjKrider, yeah I've tried the water test on the pulleys (WD40 as well). Stethoscope was not helpful either :( . It comes and goes on mine. 2022 with 29K miles. I'll look into the PCV valve as well. Thank you very much for sharing what you have tried and I will let you know if I figure it out.
Belt
Idlers
Tensioner
Alternator
Water Pump
A/C Compressor
Crank Pulley
PCV Valve
tjKrider, I am not sure but I think I found the issue. I guess time will tell but the squeak is gone. My water pump pulley had some belt material transfered to it. I took some emery cloth to it while it was idling to clean it up. Nice and shiny now. Let me know if this fixes yours.
Nice! I'll give that a try. Was your issue happening all the time? Mine only rears it's head after a longer drive and/or elevated ambient temps outside so I assumed it was temperature related. I could still make sense of pulley material transfer as the belt expands a little with temperature, though.
it was random. Seemed like every time I crawled underneath it would stop LOL. Freaking gremlins:ROFLMAO:. Curious to know if you have the same belt material on your water pump pulley. I was going to try to use a hose to listen and see if I could pinpoint the source. Stethoscope was worthless. Maybe something to try if the problem persists.
The noise came back. I used a long piece of hose to listen for the source. None of the pulley wheels made any noise. Just by accident I bumped the small shock that puts tension on the tensioner and the noise went away. I've sprayed some WD40 on the botton anchor(bolt) and the top and the noise seems to be gone. Again, not 100% sure but I think that is the source. For reference, it is the part on the left of the harmonic balancer and right of the hoses (bolted to the timming cover).
Crap. I replaced mine as a full assembly as one step in the problem solving process. Belt, then idlers, then tensioner assembly. 🤷🏻
Sounds like a bearing going bad, take the belt off and turn each pulley by hand to feel it's sticking(resistance). If it's left the way it is the pulley will seize
