Springs and shocks
Jk Jeff
Independence, mo
I have a 2012 JK is 12JK with a 3 and a 1/2 inch metal cloak lift and 37x13.5 tires. The Jeep does drive amazingly well on the road, very capable rig off road as well. I would like to get a little more clearance thinking about 4" Springs and up grade shocks. Possibly some steering upgrades which I believe is needed for these heavy tires. My question is will I have to make any other adjustments to my existing lift kit and will I need a realignment?
Are you wanting more ground clearance or tire clearance, if it's tire just put on some flattop fenders. Then you don't have to mess with your suspension since it's good.
I may go to 38" tires for some slightly more ground clearance but I am looking for Fender Clarence and I do have flat fenders I got the metal cloak finders. I think my Springs may be slightly worn out as well it does not set level. I have had my tires bind up a couple times in the front I do have offset that's offset wheels and inch and a 1/2 spacers.
Reactions: mrjp and BLACKJKU
