hippy1972 New Member Joined Dec 14, 2023 Messages 4 Location Salem ohio Apr 17, 2024 #1 I just changed oil Sunday and it sounds like it's tapping.i used right oil and filter.oil level is good.not sure y it sounds like this I'm lost
BLACKJKU Moderator Staff Member Lifetime Supporting Member Joined Feb 22, 2020 Messages 4,877 Location Huntington In Apr 17, 2024 #2 hippy1972 said: I just changed oil Sunday and it sounds like it's tapping.i used right oil and filter.oil level is good.not sure y it sounds like this I'm lost Click to expand... Is this the first time you've changed the oil in it?
OP hippy1972 New Member Joined Dec 14, 2023 Messages 4 Location Salem ohio Apr 17, 2024 #3 No 2nd time
BLACKJKU Moderator Staff Member Lifetime Supporting Member Joined Feb 22, 2020 Messages 4,877 Location Huntington In Apr 18, 2024 #4 hippy1972 said: No 2nd time Click to expand... Did you use the same weight of oil and did you change to Synthetic and used Conventional last time?
OP hippy1972 New Member Joined Dec 14, 2023 Messages 4 Location Salem ohio Apr 18, 2024 #5 I used pennzoil ultra platinum full synthetic 5w20.same as I used the last time
BLACKJKU Moderator Staff Member Lifetime Supporting Member Joined Feb 22, 2020 Messages 4,877 Location Huntington In Apr 18, 2024 #6 hippy1972 said: I used pennzoil ultra platinum full synthetic 5w20.same as I used the last time Click to expand... Thought maybe there was a heavier weight oil in it last time, do you have the 3.6 engine?
