scanner indicated vacuum leak
dgard1
Forest, VA
Recently connected a Blue Driver OBDII scanner tool to my 2014 JKU. Scanner feedback indicates a small vacuum leak detected. What are tried / true methods to determine the location of the vacuum leak? Thsank you. Respectfully, DG
Is it a vacuum leak in the evap system? If so some have had rodents chewing on hoses or else the rubber pieces have cracked.
