Ok need some help. The panel has built in led voltage meter. The switch panel word to the battery. Have rock lights wired up to a switch panel. Problem is i have to have key on to turn on the lights. How can I wire up the lights so the jeep doesn't have to be on? Do I have to bypass the switch panel or is there a way to use the switch in the 6 gang panel? I like not having constant power to the whole switch panel. Worried about battery drain if the switch panel is constant with the voltage meter.
