Question Of The Day- Can Half The Driveshaft Be Replaced- Safely?
I recently bought a 2012 Wrangler Rubicon from a dealer. During the pre purchase inspection, I found the U joints of the front driveshaft were toast. The dealer promised they'd take care of it. It's just a simple U joint replacement, right?
This is my first JK. Prior to this, I've owned several Cherokees, XJs and FSJs (Full Sized Jeeps). I'd never even heard of Rzeppa joints until a few days ago- that's how little I know about JKs.
The upshot is, the dealer tells me the U-joints are not rebuildable. (Just to be clear, I'm talking about the forward end of the driveshaft that connects to the axle. Not the aft that connects to the T case.) Dealer says he'll either pay for the installation of a factory shaft, or will put the money towards an aftermarket shaft. Online, factory shafts cost about the same as an Adams shaft. I ordered an Adams 1350 double cardan DS.
The dealer tells me they can just replace the front half of the shaft, the back half of the shaft is still good and will cut me a check for about half of the cost of a full shaft. For a variety of reasons, I'm thinking this is hokey and the whole shaft should be replaced. My thoughts are, the only way they can get half a driveshaft is to cannibalize one from a junkyard and that's not acceptable.
Am I off my rocker here? Does someplace sell a new half that can be used to return the front drive shaft to service?
Thanks
Thanks
