I want to replace my clutch and fly wheel on 08 JK but there are so many different variations. Any recommendations?
That was supposed to be clutch. Does it matter on the size. Some are 12" up to 15". All say they match. Thanks for the inputWhat do you mean when you say "clits" help?
Centerforce Dual Friction, she's gonna like it.
My National TOB and Luk clutch kit is working fine and quiet. I also used a Luk flywheel. Some say replacing the flywheel is not necessary.?If so, should I have my mechanic order a LUK clutch kit and a separate National TOB?
Flivver, how’s that National bearing going for you? Any noises so far?
