Went for a drive and came home to a hot wheel and smoking brake pads. I’m guessing stuck caliper. Too dark to take her apart right now. If it is should I go OEM or get a duralast from auto zone?
Might also replace the rubber brake line on that side in case it went bad on the inside. If you have a NAPA i'd say buy one there, I haven't had good luck with AZ parts.
