PO113 Engine codes
mfinn
Olympia, Washington
Took my 14JK in to the dealership a couple weeks ago to replace the oil filter housing and cooler.
They did not have a oem one in stock. It was leaking pretty bad and leaving oil stains in my driveway so I bought one off amazon ( got the link here).
They installed it and everything seemed normal for a couple days until the check engine light came on.
I borrowed a neighbors Bosch Pocketscan ( OBD 1000).
It tells me the code is PO113 and PO113 PD.
Doing a google search says something about air intake temperature sensor.
It will have to go back to the dealer, but can anyone tell me if this has anything to do with that after market oil filter housing and cooler?
Is there a cheap fix?
Also when they had my Jeep that day, they suggested it would be wise to do the plugs and injector service.
Is that a clue?
