I had my 14 JKU Re-Geared from 3:21's to 4:11's, Now I have a P0731 code. RPM's @60 are 4000. I'm hoping i need to have pcm re-flashed or did I just throw $1600 away?
Its supposed to be 2400 rpm @70mph with 33' tires. It's 4000rpm @ 60. Something is not right.Your RPM's on the highway will be higher now with the jump you made in gears, if you put bigger tires on you'll lower the RPM's.
My speedo only seems off by 1 to 2 mphFind a GPS and verify your speedometer is reading correctly.
Is it actually running at 4000 or is the tach just displaying 4000?Its supposed to be 2400 rpm @70mph with 33' tires. It's 4000rpm @ 60. Something is not right.
33" I bought a Superchips Flashpaq F5. Problem solved. As soon as I changed the gear ratio it was back to normal.you need a procal or equivalent to update the ecu for the gears. what size tires?
Same one I have, works great.Update: I bought a Superchips Flashpaq F5. Problem solved. As soon as I changed the gear ratio it was back to normal.
