P0522 code
NR4GD
jonesborough tn
OK, i have 2012 jk 3.6. i have replaced so many parts. but....here we go again. my starter died, killed my battery...so I replaced them both, drove and sounded amazing then......next morning i got p0522 code on jscan, and the cel only comes on when it gets to normal operating temp. the oil cooler and sensors are mopar, 2 months old. i know its the right oil, i checked the oil level, good. but i broke it down and thought the oil cooler was leaking again because its the code i got when it leaked. but i cant see any leaks from the oil cooler. i did find a small leak from the passenger side valve cover but its small, it might be from the pcv valve hose, (i replaced it when i did the oil cooler), maybe knocked the hose loose when putting in new battery???? but either way...it wasnt there before. i dont know how to check the voltage or anything on the sensor. or how to do the piv for oil pressure on jscan and dont want to keep throwing parts at it if its not the problem. any help would be much appreciated, life is hard right now, and i kinda need a hand up. thank you
The P0522 code indicates that there's a problem with the engine oil pressure sensor or the circuit. Since you’ve recently replaced several parts, let’s break it down into manageable steps to help you diagnose the issue.
1. Inspect Wiring and Connector: First, check the wiring and connector to the oil pressure sensor for any signs of damage, corrosion, or loose connections. Sometimes, a bad connection can cause intermittent issues.
2. Testing Oil Pressure Sensor:
- If you have a multimeter, you can test the sensor. Disconnect it and measure the resistance at the sensor terminals with the engine off, then compare it to the specifications in your repair manual.
- You can also check the voltage supply to the sensor with the engine running. The signal wire should output a voltage that corresponds to the oil pressure.
3. Verify Oil Pressure: You can also verify the actual oil pressure using a mechanical gauge. This will help determine if the issue is with the sensor itself or if there’s a deeper problem with oil circulation.
4. Oil Level and Quality**: Although you’ve checked the oil level, ensure that it’s the correct type and hasn’t degraded. Sometimes, low-quality oil or the wrong viscosity can affect pressure readings.
5. PCV and Vacuum Leaks: Address the small leak from the passenger side valve cover. A vacuum leak can cause erratic engine behavior. Ensure the PCV valve hose is properly connected.
6. JScan Usage: To perform a PIV (parameter identification vehicle) test on JScan, you typically navigate to the "Diagnostic" section, look for live data and find oil pressure parameters to see if they fluctuate with RPM. The app should provide on-screen guidance.
7. Clearing Code: After performing checks and replacing any suspect parts, clear the check engine light and run the vehicle to see if the code returns.
If you’re still unsure about how to proceed with the electrical tests, consider reaching out to a local mechanic or someone with more experience in automotive diagnostics. Good luck, and hang in there!
Reactions: Artisanau
OMG what a great help! ok the "valve leak" is right under the pcv valve, i replaced it same time as oil cooler, but putting the battery in it could have unplugged the hose, which caused the leak, AND that code!! since it all happened at same time... i will check that when i get home so im praying it is. i guess i will start testing the sensor with a multimeter if it doesnt work. thank you so much! i really appreciate you!
Nope I was not lucky. It’s the oil cooler gaskets. Again. This is the 10th time since the beginning of March it’s leaked. Before I tried different coolers. Different seals and they didn’t work but I got mopar whole thing and it was working great but now it leaked again. Please any help.
What oil cooler part number is on it now? Where did you get it from? Mopar or aftermarket? Aluminum? What brand if aluminum?
I’d just do a careful and methodical install. It’s not hard to damage the seals during install and that will lead to future leaks.
The wierd thing is. My starter went out, It killed my battery replaced both next day. Then I got the p0522 code 5 min after going to work. Found a leak on oil pan, valve cover and oil cooler that wasn’t there day before. I checked pcv valve and the needle was up with the engine off??? I toouched it and it dropped, so I cleaned it out and it rattles good. It’s brand new !!! Could that have cause the 3 oil leaks that was not there the day before or could it be the hose pulled off a little when installing battery. It was a fight!
Sorry but I’m really struggling to understand this post. A loose PCV would certainly leak oil.
I’m sorry, I’ve had so many things happen lately. Marc, I put in new oil cooler/mopar, and Pcv valve. Worked perfect til the other day my starter went out, and killed my battery. replaced them and drove to gas station, perfect, next morning I left for work and my cel p0522 got back home, it was my oil cooler leaking again, but….i found small valve cover leak, oil on crossbar, bell housing and oil pan. I checked pcv to see if it was stuck since all these leaks weren’t there the day before. But when I took off the hose the needle was half way up??? I took it off and cleaned it and it rattles again but Now need to do the dang oil cooler again..I am hoping all this is from moving things around when I did the battery , and hoping anyone can help thanks
Guess this is a different login/same poster?
What help do you need?
i dont know how that happened?!?!? mustve been old account. well, i replaced my oil cooler, again...and my pcv valve. then 4 months later my starter died and killed battery, the day after i replaced them, my p0522 came back and i knew it was my oil cooler. but the weird thing is i had a valve leak, and oil on crossbar and bell housing that wasnt there the day before. i checked pcv valve and the needle was stuck up, so i took it out and lubed it, and it dropped back down and rattled afterwards. i put it back on and redid the oil cooler.....again when gets to operating temp, the p0522 comes back. could the pcv have been bad, its weird all this happened right after the battery and starter. please help It kind of bad right now. thank you
I still don’t understand what help you are looking for. If your PCV is bad or leaking, replace it. If your oil cooler is leaking, replace it. I’d also replace the sensors in the oil cooler and would use genuine Mopar. Mopar isn’t necessarily better than aftermarket but they should meet manufacturer specs and since it’s a pain to get to, I’d prefer not to roll the dice on aftermarket. Maybe someone has experience with what aftermarket sensors are known to work well with the oil cooler. But, I’d use brand new Mopar sensors.
I’m not sure if you have actually confirmed the oil cooler housing is actually leaking. Very good chance your pressure sensor is bad. Of course to replace it you’ll have to get to the oil cooler. You might be able to replace it with the cooler on the engine but it’ll be a lot easier with the oil cooler off the engine. That’s why it’s best to use new sensors when you do the oil cooler
all mopar oil cooler put in march. maybe new battery cause a short to pressure sensor?? i used jscan and it shows very low oil pressure but the engine sounds great. i put the oil cooler in again, no leak yet so i pray its just the sensor shorted out. i just dont understand how a couple oil leaks just appeared all at same time after new starter and battery?????
Some things are related and some things are just a big coincidence. I doubt your battery replacement is in any way related. Did you replace the sensors when you replaced the oil cooler? Or did you reuse the old ones? The pressure sensor is notoriously short lived so always replace it with new when replacing the oil cooler.
My P0522 code was low voltage from the battery. I replaced the battery with a yellow top. The code came back few days later. I ended up replacing my battery terminals, charged the battery, and also disabled the Tip Start function. Code never came back.
tip start? i always get this code when my oil cooler leak....again. im gonna break it down and check....again
all new mopar cooler setup. 4 months ago
And I’m asking again, did you replace the sensors? The OE cooler doesn’t come with sensors. At least all the genuine Mopar ones that I have seen don’t come with sensors. If it came with sensors, it might not be OE Mopar. Did you buy it on Amazon? Amazon is notorious for selling counterfeit parts
Tip start is when you turn your key to start the Jeep but you just turn it forward for a second to start it instead of turning the key and holding the key in position to start the Jeep.
Reactions: Mopar
