Have this code on 2007 Sahara jku and have replaced the throttlebody and gasket, the MAP sensor. The alternator is functioning correctly. Tryn to figure out if it has a power steering pressure switch. Can't get a straight answer anywhere, help...
Yes it has oem TB. Thanks ill try the reset todayThat code has to do with your Throttle Body, did you buy a OEM Throttle Body? Try doing a hard rest so that your Jeep will relearn.
How to Reset the ECU on a Jeep Wrangler JK
While there are folks that swear resetting your ECU does absolutely nothing, it's a common practice among automotive enthusiasts. The ECU (Electronic Control Module) "learns" your driving style and the parts in your ride by storing information in its memory, information that it gathers using a...wranglerjkforum.net
Not really but I did find out it was a bad throttle body so I have a OEM one and will install mondayAny luck fixing it yet?
Ok I'll give it a shot thanksI know it took 2 different times to do the gas pedal reset for me, one time I did it slow and then the next time I did it a little faster with the pedal.
