so guys, I threw a check engine light ran home put my code reader on it and now I’m pulling a P0301 code I swapped coil from cylinder one to cylinder to to see if it would follow and it didn’t so I then replace spark plugs, just to see if that was the problem it seems to be that none of those work, and I’m still throwing the code next option would be to look into injectors was wondering if anybody had this problem and found any solution without having to pull the injectors .
