Afternoon once again. Here's the scoop. After replacing the thermostat, radiator cap, and multiple burping I thought the overheating was beat. I the last week I have found that the Electric Lemon has started to run a little warm. The temp will rise near 240 and then drop to normal (210) and the repeat. Still not a blown head gasket. Checked and did not find any air in the system. I have found that the cooling fan is now runnng at full speed. I've checked for codes and only finding a code for possible bad gas cap. Now my question is, Can a bad coolant temp sensor be causing the fan speed and the continuous fluctuation in the water temps? Heater is working fine.
