2015 jku 3.6
Two nights ago it started overheating sitting in line at a fast food restaurant….. called mechanic friend, he tells me for sure it’s the water pump….
Buy new water pump, install, flush coolant…. Same issue. Previously I could get heat to work.
Thermostat was replaced 2 months ago, it failed the boiling water test, so I’ve replaced it too….. put more coolant in. I feel like I have ALOT of coolant in there, but I just keep adding more, and don’t appear to leak, other than losing a little trying to burp it.
No heat at all… over heats as soon as I get in the road… it’s currently 40°F outside
I also encountered a strange issue eairler, I turned the heat on, and my rear defrost started blinking for a minute or two, and finally started. I didn’t read too much into it, but evidently it’s something with the doors for the vents?
Do I just keep adding coolant until I can’t add any more, I’ve tried to let air out through the thermostat and tried to let it bubble up.
