oem fog light bulb replacement
pook
Delta, Colorado
New to me 17 JKU Sahara. Looking to replace my fog light bulbs to a less expensive option. I use mine mainly as daytime running lights. I looked on Amazon and there are plenty of cheap led versions but I am sure you get what you pay for. Just looking ahead if or when mine burn out. looking for better option.
Here are mine and I use them as DRLs (programmed with JScan).
Pook, I have the Xprite units that Anyboyhome shows in his post above. They have worked fine. They were easy to install and did not require any flicker adapters. But, my JK is a 2008. I have all Xprite leds on the front and they all have performed well.
Reactions: moonie28
