Hey all, I have been trying to figure out what is wrong with my 2016 JKU (Rubicon if that matters) with 77k. I have searched and searched for same issues to no avail. On 12/26 I took my sons shooting we were in about 2 feet of snow switching from 4hi to 4lo with no issues. We parked, shut it off and did some shooting. About an hour later we went to leave and the Jeep would not turn over. Interior lights were dim and seemed to be flashing. I used a jump pack with no success. I assumed it was the battery so I went and got one. Put in and still nothing and ended up towing the heep out of the woods. I had the orinal battery checked and it was bad, but still under warranty so I got a new one and returned the other one. Put second new one in and still nothing.
I have checked the fuses the TIPM to include removing the security fuse, swapped the relays around, I have switched out the ignition switch, using a jump wire I tested the starter and it turns the engine over. All with no success. I am at my wits end and hoping someone may have suggestions besides sitting it on fire. For the last 3 years, I had been dealling with intermittent ECU code P0741-Torque Converter Clutch Circuit Performance Stuck Off. It also came up with a U0101-Lost Communication with TCM, P0123-Throttle/ Pedal Postion Sensor/Switch A-Circuit High Input and P0222 Throttle/ Pedal Postion Sensor/Switch B-Circuit Low Input.
Thanks in advance for any assistance.
