No fire on 08 Wrangler
Wrangler 08
Maine
Hi guys I have a 2008 Jeep Wrangler 3.8 automatic it was running and now it has lost all fire and has all kinds of engine and transmission codes anyone ever had this happen before?
Have you checked the CEL's?
When was the last time you checked and cleaned the grounds, battery cables and clamps and battery posts? If your still using the junk Factory battery clamps replace them with some HD battery clamps.
That is the first thing I did it was running didn't have a lot of power and when I shut it off it would not start again and every light in the dash is on including a little red lightning bolt
What was the first thing you did?
Did you replace any parts prior to this happening?
I cleaned all the grounds cleaned the battery terminals and replacing no parts except for plugs and wires
How old is your battery?
You need to get the CEL Codes so that you have a idea what could be causing it.
