New to Jeep, What to look out for?
OneTwoHasan
Los Angeles
What’s up everybody!
I just bought a 2014 JK Unlimited Sport (Anvil color). It has 85k miles on it, appears to be well taken care of and not abused driven. Everything stock with no mods. Just wondering if there are any common issues to expect or just any general maintenance to be done around this mileage?
Thanks in advance!(y)
Oscar-Mike
Cape MO
I do not see any flaws in my JK '14 auto trans. Wait until you reach 100,000 miles so go for it and enjoy.
Reactions: OneTwoHasan
IdahoJOAT
Idaho
Following. Just bought a 14 JKU, mostly stock as well.
Looking at the heated seats not being hot and the lack of a backup camera as the biggest priorities.
O
OneTwoHasan
Los Angeles
Agreed on the backup camera! I live in Los Angeles where the heated seats is not really an issue for me
Ballermaris
Atlanta GA
Umm... Hmmmm.... Make sure someone did not play submarine. Seen that a few times, other than that, better half will be hiding checkbook, credit cards, and bar you from making any online applications for vehicle improvements from those strange guys on the corner.
JimNH
Nashua, NH
I just bought an 08 with no real idea of service history and 150K. plan to replace the air filter, plugs, wires and serpentine belt - also check all fluids and probably change/renew the coolant. Other than that, tire pressure and regular oil/filter changes. Someone suggested replacing the O2 sensors, PCV and EGR valves is not needed since those would all throw a code if bad. I did get an ODB2 reader and will check to see if there are in fact any codes.
Ballermaris
Atlanta GA
If you replace any of the 02 Sensors, you have to go OEM an for the valves the same thing as the computer gets acid reflux if you use the wrong stuff.
