New shoes
franka548
Fortuna Foothills, Yuma, Az.
Finally new shoes 35's
Speaking of airing down, I plan on running my Toyo Open Country III 12.5\70-17 tires at 28-30 pounds.
When you run them at that pressure, does it affect wear and rotation?
I dig the rims, good look.
On my Toyo MTs 37/12.5 E rated, I run 27-28psi usually and that's right where they run and wear the best. Even a small move to 30psi I can feel the lugs and tell its cupping.
I rotate my own tires every oil change. Too expensive to allow uneven where on these tires.
Reactions: mrjp and Claymore
Just do the chalk test and that will show how much tire is on the ground. There are some Videos on how to just in case your not familiar with it.
With my 32s I ran 27, 28 pi and everything was fine. I will start out with these at the same and then see how it handles. Going out on a desert run tomorrow, so will set them at airup. Right now there is 38psi in them from the tire shop
Frank
