New alternator and power door locks / alarm
Firedude34
Harrisburg, NC
2007 JK manual speed
Needed a new alternator. Swapped alternator with a new one (not rebuilt) from O’Reilys. The larger of the two.
Now door/alarm remote does not work. I had the key remote checked and it is putting off the signal. No issues with ignition. Had a new key made. It puts off a signal. But it will still not control power door locks or alarm.
All fuses and wiring have been triple checked. Everything else works as it should. I just have to manually lock and unlock doors.
Thoughts?
Welcome to the forum! Did you try disconnecting the battery and letting all the electronics time to reset?
is this something I can do several months after install? I swapped the alternator out in September. Just now thought to pose the question on the forum.
It's apparently a thing. I didn't believe it either when people told me about it but yea, leave your battery disconnected for like 15 minutes to an hour. It apparently does a purge of the electrical system.
Reactions: JeepJeezy
