Need Wider Fenders
Ok I'll bite, since I've learned you never say something without substantiation.
Is it not possible to get sufficient clamp load on a JK spacer due to the size/material of the lugs? Or is it there not enough structure to support and transmit the load to/from the wheel? I haven't run the threaded fastener equations to understand them at that level. If so, then I'll modify my response in future posts. Always happy to learn! 😀
FYI - My experience is different then yours. A career in engine design where we commonly traded continuous material for an extra highly stressed bolted joint for various reasons. 1st hand motorsport involvement where I've seen more failed crappy wheels and can't recall seeing a spacer-related failure. However, I'm new to the Jeep world so my knowledge is more theoretical, not practical, based on where the limitations are on a JK.
I'm sure you're familiar, but let's do a quick review for those not familiar with the math...
When, T = F x d (I'll stick with simple letters here instead of Greek in case some browsers don't display properly)
Where:
T = torque
F = force from weight/impact/movement
d = distance
Take a simple example here: say a tire experiences a 2000 lb equivalent load going over a bump. Let's say that the wheel offset is 3", which would make this moment come out to 6000 lb-in (2000 x 3). Now do the same math, but add a 1.5" spacer into the equation, and you're now at 9000 lb-in, or a 50% increase in bending movement.
It is important to note here that the above applies to both spacers, as well as wheels with the same total offset... from a mechanical standpoint, a spacer is equivalent to a wheel with more offset. The problem is that although the moment arm calculations between the two (spacers vs larger offset wheels) is mathematically identical, this is not the only factor at hand.
Other factors that affect reliability are:
  1. Spacers are often made of aluminum and are prone to thermal expansion differences (aluminum generally being ~2x that of steel). While this isn't a catastrophic issue by itself, it will affect clamp loading over time, especially during heavy and repeated braking.
  2. Tiny, microscopic movements between the hub-spacer and spacer-wheel can lead to interface fretting. With 2x the clamping surfaces, this conceivably can occur twice as much, and in locations where salt, naturally acidic rain, shock loading, etc. can occur, this can add up
  3. Tolerance stacking is another issue here. With the addition of a spacer, you have additional runout potential, concentricity errors, and tolerance accumulation. Even barely measurable differences can add up and create micro vibrations, imbalances, and cyclic loading. While good quality spacers lower this, it's just a numbers game when you start adding more components.
  4. Spacer rigidity - where we previously just had one set of studs, with spacers there are now two stud sets and two torque interfaces which can cause the spacer to flex ever-so-slightly under load. This is of course exacerbated with larger tires, heavier weight, high side loads, etc. Even billet spacers are not infinitely rigid and under heavy lateral loads, there is some measurable elastic deflection. Repeated over thousands of miles, the repeated flexing can cause fatigue and eventually fail (aerospace learned about this the hard way many times, including unfortunately very recently)
  5. Separate from #2 above, galvanic issues can also cause issues outside of preload loss and fatigue, though these are generally manageable "seasonally"
  6. Related to #4, the JKU uses 1/2" wheel studs. While these will indeed provide sufficient clamp load in a static situation, with thermal expansion differences and enough spacer flex, a 1/2"-20 stud can start to experience shear forces instead of just tension loads.
Unlike in your example where a bolted joint has advantages and itself becomes an engineered structure, wheel spacers add complexity, interfaces, tolerance stack-up, and additional opportunities for failure. While I certainly don't think they're the death sentence that some people on the internet pretend that they are even top quality spacers still have some inherent issues about them that would prevent me from empirically saying "only the cheap ones are problematic". Anecdotally, I've seen too many failures (not 100's or even a dozen, but enough to stick in my head) from people that would otherwise be considered excellent fabricators and/or anal-retentive folk (like myself!) to say that they are simply "maintenance related issues".
Are the "bad"? Certainly not. Would I use spacers? I can't imagine a situation where I would (at least not long-term) :)
Certainly. This is why I qualified a part of my response with "crappy" wheels. I've seen my share of casting porosity, inclusions, etc in lots of aluminum castings - simple and complex. Low price many times = low quality. This is why I like OEM wheels or something on par when dealing with aluminum.
I don't have spacers, but I think the use case here is someone that wants to run a bit larger tire like the OP. Given the choice I'd prefer a quality spacer over a crappy wheel - for this type of use case. Crappy castings to achieve the same geometry will flex, compress and relieve, possibly fracture. Short answer is there's no free lunch.
I thought about this when I was typing my response. If someone is putting tons of cash into lift, suspension, gears, etc just pony up the $ for a quality wheel with the correct offset. No disagreement here at all!
Reactions: pc1p and Cimmerian
I’m stuck on this right now. The po or original owner put on some ($$) raceline beadlocks. Then put on 1.5” spacers 😖. The reason for the extra offset (best I cal tell) is for steering clearance. Imagine a set of high end raceline wheels mounted on teraflex 60’s with spacers. I use it hard enough (abuse??) to probably justify getting the correct offset wheels.
Hi everyone. First time posting. I have 2016 JKU Sahara and I just installed 275/70/R18 33s with 1.5" wide Spidertrax wheel spacers. Of course, after I did this I learned that my Jeep wont pass the yearly inspection if any tread is protruding past the fenders. Looks like my tires are about 1.5" past the fenders. Can you recommend any wider fenders that will put my Jeep into compliance? Preferably fenders that wont cost me over $800.
For the inspection issue, the cheapest permanent fix is a set of fender flare extensions. The RedRock 4x4 ones that got linked above will do the job for way under your $800 budget. Bushwacker and Smittybilt also make wider replacement flares if you want something that looks more OEM+.
Now, about the spacer debate going on above — I get both sides. The "just remove them" crowd isn't wrong in theory. A spacer adds lever arm to your wheel bearings, and a cheap cast spacer with open-ended lug nuts from Amazon is genuinely a bad idea. I've seen those fail.
But your setup has a real problem: you said the tires rub the sway bar without them. So "remove the spacers" also means "buy different wheels with the right backspacing," which isn't free either. If you're going to keep running spacers, at least run them correctly.
When I was figuring out what actually fits a JK, I read through this Jeep Wrangler JK wheel spacer sizing guide to double-check the bolt pattern and center bore before I ordered anything. The main things I'd look for if I were in your shoes:
  • Hub-centric only. The JK hub bore is 71.5mm and the bolt pattern is 5x5. Don't trust a "universal" spacer.
  • Forged 6061-T6 or 7075-T6, not cast. Cast aluminum fatigues and cracks.
  • Grade 10.9 or 12.9 studs, torqued in a star pattern to spec.
  • Re-torque after 50-100 miles, then check them periodically. A loose spacer is a dangerous spacer.
I run 1.5 inch wheel spacers on my JK for the same sway-bar clearance reason. Two years and one Moab trip later, no vibration, no loosening, but I check torque every oil change like a paranoid old man.
If you can swing it, better wheels with the right offset are the cleaner long-term fix. But if you need to pass inspection next week, wider flares + a quality hub-centric set is a totally reasonable path.
What flares are you leaning toward?
