Need help jeep overheating
bumjeep
Oklahoma
I've replaced the thermostat twice, the water pump, radiator, replaced cooling fan fuses, burped it more than a baby, and replaced the engine coolant temp sensor. When ever I'm driving it will stay steady in the 210's but if I got above 60mph I end up almost red lining at 240-250 area. My fan turns on at 224 when idling and will usually go back down to 210 very quickly. I've ran out of any options except buying a whole radiator fan and before I do that I'm hoping for any help.
It's a 2016 wrangler unlimited sport with 90k miles
So I read 49 and what im getting is check for oil but my fan turns on before the 225, so im kinda confused about what I need to do
Go down to where it says " NOW FOR THE REAL ISSUE THAT CAUSED EVERYTHING TO CASCADE INTO MAJOR ISSUES:"
Update I replaced the fan and that started to work better, but now I have a back flow of coolant in the reservoir so I replaced the reservoir hose and the radiator cap. The cap is a oem 18psi and I'm still overheating. I need help please
