I currently have a 2005 LJ that I plan to keep, but I need a 4 door Wrangler to fit the whole family on overland vacations. Some time in the next year, I expect I will be making a purchase. Until then, I am trying to get my head around all the pros and cons of the JK and maybe a JL. Looking into JKs and JLs, I see pros and cons to each. The JK has proven reliable where the JL gives me some concerns. However, the JK appears to be notorious for bending the front axle. To the point where Jeep corrected the issue with the 2017-2018 Recon. They also put a stronger axle in the JL to help avoid the issue. So although the Recon looks like a great solution, I find the price of used Recons to be similar to used JLs with similar features. In fact, I can build a new JL with cloth interior and a manual transmission for only slightly more than a 3 year old Recon. So there is little to no cost savings in a Recon vs a JL. At which point I start to lean towards a JL. But if I look at older JKs, I can save $10,000-$15,000 or even more depending on how old and how many miles
So that brings me back to my question. Looking at a 2012-2018 JKUR, how likely am I to bend an axle? I will be running 35s at a minimum and doing easy to moderate trails in Colorado and Utah on vacation. But the Jeep also has to transport me and my family 1200 miles each way from ND to get there. So I really can't afford to have a breakdown on the trail 1200 miles from home. So the cost of buying a Recon or JL upfront might be worth it if the risk of bending an axle is too high.
So I really need to know just how serious this issue is? How common is it? When does it happen? Can a Jeep with a bent axle still drive 1200 miles to get me home or will I be stranded on a trail and need to find a local towing company and shop to take care of me? What does it cost replace the front axle if all the work is hired out? Any help and experience is appreciated. I can see this is going to be a toiling decision over the next year or so. Thanks.
