Navigational compass issue
Billyum
In.
2011 3.8 wrangler. Navigation compass has reverse sensing North is South. South is North. Can't get the CAL. to light. Just goes to outside temp.
Anyone know of any remedies?
When mine did that I had the antenna end for the Compass turned wrong.
Where is the component that calibrate and what does it look like
It's under the center section on top of the dash on the left side, it's like a coax cable with a box on the end of it. There might be more info with pictures on the web, maybe tomorrow I can check.
I check under the dash above the radio. Saw nothing but a connector just hanging. 2wire with 4 pin holes. Nothing to connect them to. Took the radio out but nothing their to connect them to. Seen only cable is radio cable. Their was a 6 on to connect to but no wire connector for that 6 pin..
Where can I order the navigator component?
