The only thing I can think of is that US Military ground vehicles have a separate set of lights called blackout lights. They are specifically designed to be as hard to see by enemy forces as possible. They pretty much have only enough light output to be visible through the use of night vision tech of some sort.
What that would have to do with a jeep I have no idea. Try turning it on with your jeep and see what happens. It may eliminate some functionality like blinkers or brights, or lower the voltage output of the lamps.
It probably doesn't do anything though and is something imbedded in the base software that JScan and other such apps use.
