looking for inner fender that are easy to install along with mid width flares
Jack102
North Jersey
Hey all, just wanted to see if you guys have any opinions on certain inner fenders/flares that I should install on my Wrangler. I would like to not have to drill anything if possible looking for some simple bolt on install same with the flares. I have 35x12.5 inch tires so would also need to make sure they wouldn't rub. Look forward to hearing your thoughts.
Reactions: vaffanculo
My experience is limited to my 2016 JKU with 3.5" lift and 35s. I swapped flares and liners out for the pictured ones. In my defense, I did wrench for a living and didn't have one hole to drill. I did install rivnuts in all the holes to really simplify the install. No trying to get a wrench on a blind nut makes it very easy to pull them when needed. They DO NOT rub at full flex.
Wasn't sure I'd like the flare's running lights, but they are a godsend in the pitch dark. They are wired direct to the front and rear running light harness.
Flares and liners are an Amazon buy.
https://www.amazon.com/dp/B08QVCQBC6?tag=jkforum-20 are the liners
https://www.amazon.com/dp/B07RTN38SF?tag=jkforum-20 are the flares
Reactions: Jack102
They all pretty much bolt up like stock, lift has nothing to do with it. Find a style you like and run with it.
Hey jack good morning so I have a 2008 j/k and didn't want too spend 400 bucks for four new half fenders so I went on you tube and made them myself basically a oem fender is what they start with when they make the cuts ..so make a chalk line on your fenders how wide and the curvature you want them get a fine tooth jig saw and get too work on your new look I did it with my 08 j/k
Reactions: Jack102 and BigAL07
Here's some better pictures plus the wire that you will unplug from the side mount lights are a quick connection if you ever want to connect rock crawler lights
