New here and tried searching the threads but too much to find. I need help. Last week when I left for work the jeep started to act funny every time i pressed the gas pedal. It finally stayed on but the gas pedal limp. Could not rev engine. Codes were p0571, p0108, p2167. Well I replaced the throttle body, accelerator pedal, MAP sensor, Brake sensor and a brand new battery. The jeep starts perfectly without hesitation but still limp pedal. I did the ECU reset and the throttle and pedal relearn. Also absolutely zero codes
Yesterday I was told i should have not purchased any parts from an outside vendor other that direct OEM parts. Is there an issue with the parts that are not genuine jeep parts. Ive spent well over $600 already and no luck
