I bought a 2011 Jeep Jk with known issues...I put new heads on it ..plugs.. wires..tstat.. temp sensor..
Got it all back together and I started getting the lightening bolt on dash
Never got it before heads were removed so I'm sure it's something I did
Checked intake...all vacuum hoses..checked wire harness...did idle relearn 50 times...even bought new throttle body...still getting display
If you let the Jeep idle, the display comes on in about 3 minutes, if you take right off it takes about 15 to 20 minutes to come on.
Shut the Jeep off and restart it and the entire sequence starts again
No throttle position sensor code...no air intake sensor code..
Not sure what else to do
Any help would be appreciated!
