Lifter / rocker replacement
najamerson
S Carolina
I have a 2015 JKU Sport w/ 107,000 miles on it.
I'm starting to get all the parts I need to replace the lifters/rockers in my 3.6, other than the lifters, rockers, and valve cover gaskets, what else would you change while you have everything broke down and apart?
I just replaced the oil cooler housing, knock sensors, spark plugs, and thermostat housing.
How bad is the tick? Might need cam too. Aluminum oil cooler if you're already in there.
