What brand driveshaft did you get?
@Danarch
@Jskunk
@Cimmerian
What tires are you running on your 2.5” lift? I might like to increase the size over stock but I don’t want to have interference with flexing off-road or lose too much power being undergeared.
315/R70/17 Mickey Thompson Baja Boss ATs
Keep in mind I also have swaybar disconnects, adjustable control arms and 5.13 gears.
Yeah I wouldn’t go that big due to the gearing, but you can fit them on a 2.5” lift?
@Danarch
@Jskunk
@Cimmerian
What gears are in your JK?
Stock Rubicon 4.10s
255/80/17 or even 34x10.5-17
I'm leaning toward the AEV; it has the least components and is therefore the least expensive, but if it turns out to need other components I can add them later. I'd like to avoid their Geometry Correction brackets since they would reduce ground clearance by a few inches right behind the front wheels.
It seems to me that leaving the front track bar completely stock would decenter the axle enough to cause issues, but I'm willing to take them at their word that it's not necessary for now.
it also seems that leaving the front LCAs unmodified could cause pinion angle problems for the driveshaft, but again if there're vibes I can deal with that later. By the same token, I'm a little dubious that the rear sway links can stay stock, (I have SwayLOC in the front so no problem there), but longer rear links shouldn't be too expensive.
For some reason I can't access the Teraflex site in the last couple days; there's a server issue per Cloudfare.
I want to keep the stock wheels; if I put on taller tires but keep the width around the stock 10", can I avoid spacers? E.g. 255/80/17 or even 34x10.5-17.
You won’t get driveline vibrations. That starts becoming a problem with higher lifts and adjusting the lower control arms forward. Keep a close eye on the front Rzeppa joint at the transfer case. When the boot shows tearing, replace with either a high angle Rzeppa joint or a new driveshaft with a double cardan joint.
Lifting without adjustable control arms (or geometry brackets) and an adjustable track bar WILL cause the axles and caster to be off. No way around it. But, at lower lifts it’s not much so you can get away without adjustment. Personally, I would not. But, it WILL work.
I’m helping a friend with a spacer lift later this year and I told him I would only if he did the lower control arms and an adjustable track bar. I want him to be very happy with how it rides and drives. He could do the lift without those parts but he’s on his own if he does. He wants it to ride well so he’s going to take my advice. He’s going to buy all the parts gradually as he can afford it and once he has everything, we are going to do the work.
Yeah I would be open to correcting caster; sounds like it could be done more economically with Teraflex fixed length LCAs than full adjustables.
@Danarch
@Jskunk
@Cimmerian
I ordered the Teraflex mid-level Trail Select kit; I’ll post the install in my build thread. Thanks for all the input!
We got my college son a 2014 JKUR last summer with the expectation he’ll bring it on family jeep days to help carry parts of the large family.
We took it out on a moderate trail and it did okay, but had trouble scraping on some larger obstacles that the others (TJ and LJ both on 33’s) went right over. It’s totally stock except for a SwayLOC.
I’m considering a small lift without breaking the bank. I’m not sure I would even put larger tires on it because they’re already basically 33’s and I don’t want it to be undergeared.
My reference is the LJ which is on 2.5” OME springs and shocks with a 1.25”body lift. Longer links and adjustable trackbars.
The 2.5” kits from Teraflex and AEV look pretty good for about $1200. I figure I should be okay with stock control arms and driveshafts.
Any comments on those kits, or recommendations for others? Do JK’s need body lifts? Heck I’d consider 1-2” spacers.
