I was quoted a Rock Krawler 07-18 Wrangler JKU 4Dr 2.5" Adventure -B51 and a Rock Krawler Bump Stop Front/Rear kit (1"-4"). I have a 2017 JKU Rubicon HR. I got it back and it looks really high and the steering seems to be much looser than before. I'm having to make way more left and right corrections than before. It looks much more than 2.5" higher.
The front springs are etched 08 0824 with a sticker labeled RK02001. The measurement from the top of the spring to the bottom is 15.5".
The Bilstein shocks are labeled 24-186995 B8 5100. On the front the measurement is 24.25" from the bottom of the shock mount to the center of the bottom bolt.
The rear springs are etched RK02002.
Other pieces are labeled JKS and J-Link
Then, after the kit was installed, they showed me seized fittings on the Tie Rod and Drak Link and they installed Currie CURRECTLYNC steering system, which looks like the joints are really crooked.
I'm wondering if the place just pieced together a lift kit from parts they had laying around. Any input would be appreciated. I want to make sure I know what I'm talking about if I need to go back and address this.....or does this look normal?
2 more measurements to add- the center of wheel hub to inner lip of fenders are about 26" in front and 25" in back.
