Leveling kit tire size
Ncjquinn
Is anyone running a 2inch leveling kit with a 305/70/17. Just looking to see how the setup performs.
thanks.
Should be fine as long as you aren't using stock wheels. You may not have max articulation, but you really only need to worry about that if you are disconnecting sway bars.
That being said, I have 285/70/17 with a 2.5in lift with basically a 33" to the 34" tire you are suggesting. I could easily fit a 34"
