Left multifunction turn signal lever acting wierd
Stormydog
Illinois
My inside cab lights come on and stay on sometimes when I hit a small bump on the highway, I have to play with the left lever a little to get them to go off, sometime they do and other times it takes longer to get the inside light off. A common problem or might I have a problem with the left multifunction lever/turn signal control?
It isn't a common problem that I'm aware of.
Could be the multifunction switch, could be a random ground somewhere.
I mention the ground because a faulty ground is a common reason for jeep gremlins, though usually a bit more mischievous than what you are describing.
Reactions: Lxxtsy and BLACKJKU
I'm guessing it's the stalk. I've replaced a few JK/KJ multifunction switches over the years. I wouldn't say it's common, but by your description I think it's likely.
Check grounds first since it's free, but I think the switch is the culprit.
