JK Floor Pan Replacement
Bucc18
NJ
Need some guidance from those with experience!
My '09 JK front driver floor pan is rotted right thru.
I bought a replacement made by Key Parts. I've never done a replacement like this, but would like to save the $$$.
I got quotes from $2k to $600.
The $600 (from a very well established body shop) is attractive, but he is assuming 8hrs of labor and won't guarantee it is enough time.
Any thoughts or recommendations? TYIA
The problem with rust is ya don't know how bad it is till you start cutting it out. What size is your replacement pan? It's not hard to do yourself. You will need an angle grinder with cut off wheels, masking/painters tape, old sheet(s), a welder or 3M Scotch-Weld Epoxy Adhesive DP420, POR-15, paint brush and some time.
