JK charging issue
Motorcyclefanatic
Knoxville, TN
The battery light on my 2016 JK started coming on intermittently, so did some investigation with the VOM.
At idle and running up to about 3k rpms I get about 13vdc at the battery, sometimes dropping to as low as 12.8. I measure a solid 14.2 at the alternator at idle.
That leads me to believe the problem must be with the voltage-regulator, which I understand is located in the PCM on these vehicles.
Looking for a consensus before buying parts.
