anyone have any experience with these? an upgrade for the stock battery cables.
it started with loose terminals and ended here lol, but with my winch and some lights, an upgrade isn't a bad idea IMO
The reason I went with the cables from the other vendor is that theirs maintains the fusible link instead of inserting an actual fuse, which is a better application imo.
Just me but I would say if the fuse or fusible would burn out at least the fuse could be replaced along side the road or woods easier.
Sure, but the fusible link only goes if there's something so bad that having extra fuses isn't going to help even if you do have extras.
A temporary over-amperage situation with a fuse means you better have an extra fuse. A fusible link means nothing goes pop.
It's also fewer connections to have problems with.
Yea just everyone's preference, I dealt with the ole fusible links on the old Dodges to long. Everyone that ever had problems with them always switched them over to blade fuses and had no more problems.
But With a dead short neither will make a difference until you find the problem.
