Is my tie rod and drag link bad
Looks like the other side is loose also, I don't see the passenger side tie rod moving much.
Usually when I check tie rods i'll have someone move the steering wheel back and forth with the engine off. Then i'll watch for movement in the tie rods.
Thanks. There was a little bit of movement. The boots are a little torn too. Most of the other YouTube videos I watched said I should be able to rotate it a little bit but it shouldn’t be loosy goosey. I also found a little bit of up/down at the ball joints. Gonna change those. Figured it would be a good time to change the other stuff if it needed it
