So I know when I change the gear ratio in the axles I will have to tell the jeep what the new gear ratio is. Once I connect the jscan to the jeep and do what I have to do can it be used on other jeeps or is it only good on my jeep.
So where do I get one and is that what I need to tell the Jeep what the new gear ratio is?It's super easy to use, thats for sure. Fixed my speedo and Daytime driving lights. Had to use my fogs for that. I have halos on my front signals that I wanted to use but, there's no provision to use running lights as DRL.
Jscan is a free download from the App Store or the Android equivalent. You need a OBD2 dongle to make it work. That's about $100. There's a section on the app with recommended dongles. I'm using the "OBD Link M
Jscan is a free download from the App Store or the Android equivalent. You need a OBD2 dongle to make it work. That's about $100. There's a section on the app with recommended dongles. I'm using the "OBD Link MX+"
I need one because I am re-gearing my axles and need to tell the jeep of the new gear ratio and tire sizehttps://www.amazon.com/dp/B071H5W7H7/?tag=jkforum-20
$32 and works perfectly! I've had it for a good while now.
T
That is correct. I changed my gears to 4:10 and the trans went into limp mode. As soon as I reprogrammed it was all good. I bought A Flashpaq. It was pricey but I changed tire size and gear size. I can program all kinds of stuff with it.I don't plan on changing anything but the gear ratio setting when I have my axles re-geared. I was told that if I don't it will go into the limp mode and won't go past 2nd gear.
This is the one I was referring to. The screen shot is from Jscan. Works fine with my '17 JK.I just ordered the Icar pro from Amazon. The ODB Link M+ will not work for JK's. That what it says on the list of supported OBD's
