How do I turn ECO mode off?
'17 JKU with no menu button on the steering wheel, no eco button anywhere. Stock CD radio with radio controls behind steering wheel.
Is there a way to turn it off? Not sure if it's a display thing or actually affects how it drives/shifts.
Thanks
View attachment 118742View attachment 118744
I own one of these and it is very simple. The trip button allows you to select between the odometer, Trip A, Trip B, And the screen that says eco. that eco text on says if your driving is eco or something else. so just press the trip button on your dash and worry only on your driving again.
Reactions: pc1p
Yo, so ECO mode is honestly one of those things that trips people up because it depends on which JK you've got. If you're running a newer JK with the newer dash setup, you should see an "ECO" button right on your steering wheel controls – just tap that bad boy and it toggles off. Super simple.
Now, if you've got an older model, you might not have a dedicated button, but ECO mode can still be active depending on your transmission settings. On my JK, I found that putting it in Sport mode basically disables ECO and gives you more aggressive throttle response, which is what I wanted anyway when I'm wheeling.
The thing is, dude, ECO mode isn't really a problem for most people – it just dulls your throttle input to save fuel. But if you're doing heavy offroad stuff or towing, yeah, you want it off because the transmission will be happier with more direct control. Check your owner's manual for your specific year since the placement of controls can vary a bit year to year.
What year JK are we talking about? That'll help me give you more precise instructions. And are you just wanting it off all the time, or just when you're wheeling?
depends what you got. if its a newer JK with that eco button on the dash just hold it down and itll toggle off. some guys just unplug that module entirely but honestly the fuel savings are pretty minimal when youre running a hemi anyway lol. mine stays off 99% of the time
