Help with installing a battery isolator
rickashane
Bend,Or
I’m installing a battery isolator relay, but haven’t figured out if there is a dedicated terminal on the ignition switch that will control the relay. Any thoughts on the matter. 2014 JK Wrangler Sahara . I see in the owners manual an accy / run relay K1, on the TIPM or if I can tap into the ignition cut at a more convenient location.
Can I ask what your plans are for the relay?
