Help with Halo LED headlighs
ghost15
Satx
Ok so I just bought 15 jku and the previous owner had installed Halo led headlights
When I bought the jk the halos weren't wired up so after the YouTube search and watching countless video I decided to wire them up and found 2 issues I don't know what brand they are but I used t taps to wire up both side and Issue 1 the tun signals don't work on either side and issue 2 passenger side is white and driver sid is blue like I said idk brand or if rgb im guessing they are rgb I don't see a wiring for rgb so maybe they took it out or I have wire switched anyone else have this issue or recommendation on how to fix this issue any help would be appreciated
Thanks
If you have 1 white wire on 1 light and a blue wire on the other light, then they are RGB halo rings. If the wires had no ends on them, then the previous owner probably cut them from the RGB brain.
The wires are red and yellow off the back of the light didn't see a rgb controller of any sort
