2015 Rubicon JKU 4" lift, 35s 65k miles
I got this JKU this summer and just noticed the front driveshaft had a lot of slop so replaced it with a double cardan shaft (single u-joint at front differential, double at transfer case).
I installed it yesterday and now have a mild vibration at 55mph that gets more noticeable the faster I go. Everything was tightened to spec, greased, and feels solid.
Reading revealed the pinion must point to the transfer case with this style DS and mine does not.
- Adjustable lower control arms should allow me to point the pinion up - is that correct? Or is it uppers that are needed? (Plenty of room in wheel well for travel either way)
- How does changing pinion angle impact the castor measurement?
- If I get adjustable CAs, do I just eyeball the pinion to point to the TC? Is more precision needed?
