Help Codes P0455, P0882 and P1745
Kingpreston85
Canton,Ohio
My 2011 jeep wrangler unlimited rubicon is showing codes p0455, p0882 and p1745 Does anybody have any ideas of what I can do to fix this problem I appreciate it thank you
Anybodyhome
USN Retired (1973-1993)
Nashville, NC
P0455: The typical evap system fault. Sometime as easy as tightening/checking your gas cap; or as involved as having to replace the evap line.
P0882: Faulty Transmission Control Relay; Transmission Control Relay harness is open or shorted; Transmission Control Relay circuit poor electrical connection
P1745: Faulty Line Pressure Solenoid; Line Pressure Solenoid harness is open or shorted; Line Pressure Solenoid circuit poor electrical connection
Read more: https://www.autocodes.com/p1745_jeep.html
Read more: https://www.autocodes.com/p0882_jeep.html
With the 1745 code, if it is legit, your JK will go into limp mode and it's basically not driveable. The 0882 code paired with the 1745 leads me to believe there is an issue with the TCM.
K
Kingpreston85
Canton,Ohio
Thank you Anybodyhome now what would you do or what are the first steps to take on this situation? Thank you so much greatly appreciate it
BLACKJKU
Moderator
Huntington In
I would first try taking it to a well known trans repair shop in your area and see what they say. Dealer would be my last choice.
Anybodyhome
Nashville, NC
How is the vehicle running/driving? Everything normal, shifting okay, no stalling out, shifting at the correct points, etc.?
In other words, if you didn't know the codes were there, would you know there's a problem?
K
Kingpreston85
Canton,Ohio
The jeep runs great handles great everything works on it as in electrical and the only that its doing is shifting only up to 3rd gear and it shifts fine but once in 3rd gear it stays there so I'm saying if the codes wasn't there I would still know that its only shifting to 3rd gear I just fixed a break caliber and put a new exhaust on it so I haven't got a chance to reset the vehicle and try that will do tomorrow night I will let u know is there a good way to reset everything on my jeep?
BLACKJKU
Moderator
Huntington In
